CML ASAv missing interfaces
C. Rod Weir
I have a 40 license version of CML.  I have been creating labs using ASAv.  I all of the previous labs the ASAv had interfaces G0/0, G0/1 and Management 0/0.  I deleted an older lab and started a new one.  However in the new lab the ASAv's have only G0/0 and Management 0/0.  I need that G0/1 interface.  ??
shin.sterneck
Hi C. Rod Weir,
you can add interfaces to the vASA by simply selecting the node in CML, opening the tab "Interfaces" and clicking on "Add 4 Interfaces". It'll add 4 more interfaces that you can then use. Hope this helped!
best Regards,
Shin
