cml lab console stuck at grub
shivraj01
cml consolecml console
Unable to log into console even after bootup is completed as seen above. It seems the grub is expecting
<return> to proceed. what can be the possible explanation and resolution here.
TIA
balaji.bandi
what is the version CML, is the same case with other nodes ?
BB
shivraj01
2.4.1. latest. Yes all nodes are not responding be it switch router or server. ssh shell enters console, shows list and labs command , but disconnects immediately after escape character with open and connect commands.
Breakout telnet 9000 enters but don't know what's the use without console commands.
is this first time installation, never worked?
what is your compute information.?
check CPU requirement :
https://developer.cisco.com/docs/modeling-labs/#!system-requirements
BB
shivraj01
trying on mac m1. don't understand when x86_64 vm is installed why cannot cisco images run on top of it, else is it like docker process.
