CML2 - cml-controller is administratively disabled
GregorF
I have upgraded CML2 community edition personal to 2.6. Upgrade have gone fluently.
When I try to make new lab and add new node (router or switch) I have got:
iosv-0: Failed to choose a suitable compute node (cml-controller is administratively disabled.)
Also, If I try to "Start" LAB got same result.
What can be wrong. I went out of maintenance mode.
You brought the system out of Maintenance Mode (new to 2.6), but did you bring the cml-controller to the "Ready" state?
Tools --> System Administration --> Compute Hosts
Select your CML Controller node and change admission state to "Ready". Being able to deny new labs starting up is also new to 2.6
Disclaimers: I am long in CSCO. Bad answers are my own fault as they are not AI generated.
Thanks Ramblin! It works!
BR,
Gregor
Thanks to you @Ramblin Tech ... It works for me now....
leoprez314
Thanks @GregorF
I had the same problem and it works for me now
