Does the track 1 command not work in packet tracer?
jc99j
This is the command i type: r2(config)#Track 1 int g0/0/0 line-protocol and it gives me an invalid input at the track part. is there a different configuration mode I need to be in or is it unsupported? I tried this on both 4000 series routers and a 2000 series router in PT with the same results. Any help is appreciated!
Torbjørn
Track should be supported. Which image are you using?
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
