Help setting up a vWLC node in CML 2.0
MartinWard9213
So, I finally made some time to install Cml 2.0, I was hoping to set up a simulation with a virtual Wireless LAN Controller but I've had no luck figuring out how to add device so that I can use it in a lab. I've wasted most of the day trawling the Interwebs looking for solutions etc but to no avail.
Gotta say, given the cost and the lack of documentation and support that so far I'm not particularly impressed.
Ollie Y
I'm not sure this would be possible to add a vWLC into CML as it's a VM.
I'd recommend you setup a separate virtual machine with the vWLC and connect it to your CML lab via an external connection.
