IOSV - 15.4(3)M for testing PFR3
Wes Smith
Hello
Just getting started with CML.
One of our initial tasks for CML is testing the latest Performance Routing Ver 3 (PFR3)
Support for PFR3 begins with 15.4(3)M with additional updates later this fall
Will we be able to get these newer IOSV images into CML?
David Martin
WesSLF2008,
Thanks for the questions and welcome to the group!  Let us check into this for you and we'll get back to you just as soon as we can.
David Martin
Community Manager
ditto!!!   with all the push on iwan and pfrv3 would be great to able to test in vios.  you can use csr image to test if required though.  only issue us they are a little heavy on resources
on the image front, some older images may be good.
