Multiple users with CML
sjarntzen
I am having trouble getting my 1.1 client to connect with a user ID other than guest.
In the User Workspace Management, I have created a new project and a user under it.  That user can log in to the User Workspace Management on port 19400.
In the client via:  File --> Preferences --> Web Services,
trying to change the Active profile and associated credentials, results in Connection refused.
Is there some additional documentation which covers addtionall users?  I couldn't find anything in the support group pages.
Thanks in advance.
bikasdas
I assume you have raised a case SR 637384225 for the same, which is resolved today over the WebEx session.
Thanks and Regards,
Bikash
Thanks for your help Bikash.
A note to thread followers...
Set up a new Project and associated user in User Workspace Management (UWM).
In the CML client - Web Services, one needs to create (and select) a new Active Profile.
Click on Restore Defaults (below).
In the pop up window. change "localhost" to the IP of the CML server leaving everything else the same..
In Master Credentials, click Change.
Enter the Project-Username and password created in UWM and click on OK.
Done.
My problem was I was going into the four Web Services -
Roster
Simulation Engine
OpenStack
AutoNetkit
...and changing the Username and Password in each.
The Username in those should stay as anonymous and the Password should be blank.
