Please help in packet tracer
jassimmohd44
I have 5 networks, each network has 2 PCs, 1 of the networks has 2 servers, 1 uses IPv4 and the other IPv6. every pc has IPv4 and IPv6. Everything is working properly and can be pinged, except for the IPv6 server. When I ping starting from it to other pc in any network it wont ping. If I ping starting from a pc on the same network it works, but if i started from another network it wont work. What do you think might be the problem?
this is the network
joselgo2
Hi Jassim.
Could you verified if you have an acl in the router?, after you do that maybe try a tracert for find where you lose your ping in order to troubleshoot your route.
greetings!
Thank you for the reply. I just started studying networking and using packet tracer so i dont know what acl is. But it seemed that my mistake was using the packet icon on the right to ping instead of the command prompt. When I realized that  and used the simulation mode I figured out that I did something wrong in the ospf routing protocol. It works fine now. Your reply made me think of the answer. thank you.
How can I delete this comment?
