Problem with IOS XRv custome image in CML2
I've a problem with custom image IOS XRv 6.6.3 in CML. I've loaded it (qcow image) and attached as second under current node definition IOS XRv. In resule when I'm adding a new node IOS XRv, I can choose current IOS version (6.3.1) and new (6.6.3). Node is booting up, configuration if exists is restored, but I see only 2 first Gigabit nterfaces from defined 4. A second, those interfaces not passing any traffic, p2p links not working, not ping , nothing. Node definition in attachment, is default for IOS XRv.
IOS XE custom image added same way is working correctly.
BR,
Marcin
5 Replies 5
MOre info. Packet capture is not seeing any traffic on link. Same happen at both sides.
joel.francois
I'm also using IOS XRv 6.6.3. In my case, I have configured a new Node Definition that I have assigned to 6.6.3 image definition.
What exact version are you using ?
I can use more that 2 Gig links on routers.
Eg, in attached topology, for example on CORE-A-7 router, there are 7 links.
BR.
Joël
I'm using exactly xrv9k-fullk9-x-6.6.3.qcow2 image. One diffrence is that I connected image to existing by default node definition in CML. And I see strange behavior with interfaces f.ex
definition is gi0/0/0/0 - 2 (3 interfaces) but in device I see only Gi0/0/0/0. Ping not working on P2P connection, packet capture also not cap any traffic on link between devices. I'll try to add a new node definition and see.
Joel, is possible to share your node definition for compare?
Thanks.
joel.francois
Hi Marcin,
Please see attached my Node definition.
Have good reception.
BR.
Joël
Thank you very much Joel! Was able to install (now i need to test) old light xrv 6.1.3 tweaking a little bit your yaml and minimizing to 3 GB RAM and 1 CPU to save infra resources!
