Problems starting ASAv in CML v2.8
JimBrown-ctr
Hello All,
Does anyone have any idea what would cause the ASAv (v9.20.2) that came with CML to *not* want to start? I even tried these versions: v9.20.2, v9.20.3.7, v9.20.3.10, v9.22.1.1.
Here's the environment OS:
sysadmin@cml-controller:~$ uname -a
Linux cml-controller 6.8.0-51-generic #52-Ubuntu SMP PREEMPT_DYNAMIC Thu Dec  5 13:09:44 UTC 2024 x86_64 x86_64 x86_64 GNU/Linux
sysadmin@cml-controller:~$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description:    Ubuntu 24.04.1 LTS
Release:        24.04
Codename:       noble
I get this output in the console when I try to boot the ASAv:
loader: Platform type set to default
Platform ASAv
IO memory blocks requested from bigphys 32bit: 196608
INFO: The system integrator has chosen not to place the requested string in the SMBIOS
DEBUG: Could not find string for SMBIOS type *** String ***INFO: SMBIOS indicates Nested KVM Environment
Wrong EFI loader signature.
early console in extract_kernel
input_data: 0x00000000023683b1
input_len: 0x0000000000749fda
output: 0x0000000001000000
output_len: 0x0000000001a76e80
kernel_total_size: 0x000000000182c000
needed_size: 0x0000000001c00000
trampoline_32bit: 0x000000000009d000
Physical KASLR using RDTSC...
Virtual KASLR using RDTSC...
Decompressing Linux... Parsing ELF... Performing relocations... done.
Booting the kernel.
Memory KASLR using RDTSC...
Poking KASLR using RDTSC...
INIT: version 2.99 booting
Starting udev
Configuring network interfaces... done.
grep: /var/volatile/tmp/tmp_volatile.88: No such file or directory
sed: can't read /var/volatile/tmp/tmp_volatile.88: No such file or directory
rm: cannot remove '/var/volatile/tmp/tmp_volatile.88': No such file or directory
Starting random number generator daemon.
warning: Device /dev/vda has no label.
fsck.fat 4.2 (2021-01-31)
Starting check/repair pass.
Starting verification pass.
/dev/vda1: 14 files, 46206/65246 clusters
dosfsck(/dev/vda1) returned 0
Mounting /dev/vda1
/dev/vda2: 7 files, 716/2092548 clusters
dosfsck(/dev/vda2) returned 0
Mounting /dev/vda2
no cdrom devices found
nr_overcommit_hugepages set to 128 for virtual platform
/asa/scripts/rcS.common: line 1856: 436 Illegal instruction python3 setup.py -q install
/asa/scripts/rcS.common: line 1856: 442 Illegal instruction python3 setup.py -q install_lib
/asa/scripts/rcS.common: line 1872: -2: substring expression < 0
CAT9k CFG directory mounting
mount: /mnt/cat9k-cfg: special device shared_mount does not exist.
dmesg(1) may have more information after failed mount system call.
shared_mount Failure
Removing cat9k_cfg
info: Running in kvm virtual environment.
Configuring packages on first boot....
(This may take several minutes. Please do not power off the machine.)
Running postinst /etc/rpm-postinsts/100-sysvinit-inittab...
Running postinst /etc/rpm-postinsts/101-dpdk...
update-rc.d: /etc/init.d/run-postinsts exists during rc.d purge (continuing)
Removing any system startup links for run-postinsts ...
/etc/rcS.d/S99run-postinsts
Loading...
/etc/monitrc:34: Include failed -- No such file or directory '/etc/monit.d/*.conf'
New Monit id: e6eb71873187b7a5fb074b49a743b356
Stored in '/var/run/.monit.id'
Starting Monit 5.27.2 daemon with http interface at [*]:2812
'intel-x86-64' Monit 5.27.2 started
The digital signature of the running image verified successfully
lina: error while loading shared libraries: libqat_s.so: cannot open shared object file: No such file or directory
Rebooting... (status 0x7f00)
/opt/ssp-mgmt-scripts/asa_cmd_init: line 115: 1153 Illegal instruction (core dumped) $ASA_CMD_SERVER > /dev/null 2>&1
/opt/ssp-mgmt-scripts/asa_cmd_init: line 115: 1175 Illegal instruction (core dumped) $ASA_CMD_SERVER > /dev/null 2>&1
INIT: Sending processes configured via /etc/inittab the TERM signal
Monit daemon with pid [1130] stopped
'intel-x86-64' Monit 5.27.2 stopped
Stopping OpenBSD Secure Shell server: sshd
No /usr/sbin/sshd found running; none killed.
Stopping Advanced Configuration and Power Interface daemon: No /usr/sbin/acpid found running; none killed.
acpid.
Stopping internet superserver: xinetd.
Stopping random number generator daemon.
Deconfiguring network interfaces... done.
Stopping RASdaemon services: done.
Sending all processes the TERM signal...
Sending all processes the KILL signal...
Deactivating swap...
Unmounting local filesystems...
Rebooting...
UPDATE: OK, after downloading every OS version from 9.20.3 all the way down to 9.14.4, it appears ASAv-9.14.4 finally booted normally after the initial 1 reboot (which I saw on the web to be normal).
0 Replies 0
