Super Copy CML Lab?
dan hale
Level 3
Level 3
Hi All,
I'm using CML version 2.2.3+build63 and I have lab with 16 routers and switches. I have this setup as it represents my production WAN. I test out new configs and possible work changes however, I have to go back and undo the config changes or shut it down. I would like to do a super copy of the lab and when making these changes keep some of the config changes I have made....is there a way to copy the lab so that I dont have to recreate it each time?
Dan
balaji.bandi
best come across as below: download rename different name and upload
BB
shin.sterneck
Hi Dan,
you can download the lab definition file as a .yaml file and re-upload it when needed. It's also a way to share you lab.
The YAML file is a simple text file that you could also edit before re-importing it.
Downloading
Downloading can be done within the lab within the "simluate" tab --> "DOWNLOAD LAB"
Importing
Import YAML into CML can be done through the Dashboard:  https://developer.cisco.com/docs/modeling-labs/#!importing-labs
Hope that helps!
Shin
dan hale
Level 3
Level 3
BB and Shin, both methods worked. Thank you both!
