two beginner questions about CML
stauntonkcom
Hi there
I have just gotten CML personal set up on my PC. My intention is to use CML to prepare for CCNP encore and enarsi.
question 1: I believe the standard router and switch images in CML are IOSv and IOSvl2 respectively. When I add one of these images to my topology in CML, I find that whether it is a router or a switch I have added, they only seem to have four ethernet interfaces. So is there a way to add a router and/or switch to my topology that will have a greater number of ethernet interfaces to work with? And also, since all of the 4 interfaces I can currently get are ethernet, is there a way to add serial interfaces to my routers as well?
question 2: I tired adding an Ubuntu host to my topology. When it booted it up, it required a login and password. Does anyone know what these default credentials are likely to be?  -- also, if there is a cisco information page that might include default credentials for some of these host images, I would be grateful to be directed to it.
Many thanks
Martin L
You can add more Ethernet interfaces to device when it is shutdown (not power on); I think limit is 16 Ethernet interfaces.
NO serial interfaces (at least I did not see one); Serial WAN technologies are going away, if not already gone, from real life and Cisco exams.
try username and password: ubuntu/cisco
you can find passwords and more in
https://developer.cisco.com/docs/modeling-labs/#!faq/reference-platform-and-images-questions
Regards, ML
**Please Rate All Helpful Responses **
stauntonkcom
Also, one extra question in addition to the two I have already asked above!!
When I click on a node in my topology, I am currently unable to delete it, because the 'Delete Node' button is grayed-out (see screenshot below). Does anyone know what I need to do so that I can delete nodes in my topology?
if device is power off, you should be able to delete it; no big problem if u cannot, just power off device and move it aside.
try it, let us know
Martin L
Regards, ML
