VIRL sudo not working on LXC images
Aki at NTV
Hi guys, just wanted to share this as it seems really annoying when you fresh install VIRL and you cannot sudo/su from the LXC container images.. not the management lxc nor the various images available like iperf enabled one.
So login to your VIRL machine running the simulations with virl/VIRL and then "sudo su" and perform the following:
(this will enable sudo from the mgt-lxc and any additional lxc machines so you can now sudo ifconfig, change interface ips/routes, etc)
1. Put this into "sudoers" file in your dir
cisco ALL=(ALL) ALL
guest ALL=(ALL) ALL
2. Run this to copy your sudoers file to all containers (user guest is for the mgt-lxc and cisco is for all the other lxc's)
for i in `ls -d /var/lib/lxc/*virl*`; do cat sudoers > $i/rootfs/etc/sudoers; done
3. Create pam.d in LXC containers
for i in `ls -d /var/lib/lxc/*virl*`; do mkdir $i/rootfs/etc/pam.d; done
4. Copy local pam.d to containers
for i in `ls -d /var/lib/lxc/*virl*`; do cp /etc/pam.d/* $i/rootfs/etc/pam.d/; done
You can of course fix this issue before booting the lxc images but not for the lxc-mgt server.. so I'm doing this everytime i boot a fresh simulation. If someone has a permanent fix for this issue i'd love to see it.
0 Replies 0
