VMware Player and Web UI issue
l8ubcdgky553
I am using VMware Player 17 on a windows machine and after shutting down the virtual machine, I am unable to successfully access the Web UI for CML after rebooting the vm.
eg. when I restart a vm, the https:[]/ web ui link will only show up when I restart the VM multiple times, or fail to show up completely. When the web ui link appears, the connection request times out when I attempt to access the UI. I have attempted to follow the guides related to: "CML-Personal running on VMware Fusion on MacOS may lose its management IP address after a shutdown" and modifying the Bridged network adapter in VMware player.
Also, I have a set of IP addresses I am interested in modeling in CML, and I have the data in a yaml format, however it is not compatible or able to be uploaded to a CML lab. Is there a way that I can model my yaml file to match the yaml files in projects such as the one below? https://github.com/CiscoLearning/ciscolive-brkcrt-2059/blob/main/sample-labs/1-ccna-vlan-config/topology.yaml
0 Replies 0
