Erasing of the content after using Proximity
gfolens
Level 4
Level 4
Once the presentation is finished how will the content be handled on the tablet/smartphone?
- can you erase the content?
- will it be overwritten when starting a new session?
Magnus Ohm
The endpoint “cache” is cleared on all of these:
* presentation stopped from touch or by removing cable
* call hung up
* room reset triggered (not sure if this is implemented, but at least planned)
If you exit your Proximity client (and kill + restart it), all content is flushed. Upon re-launching and successfully pairing, I’ll download slides that are cached on the endpoint (see above).
Do you mean what happens if you are in a call and get content in the app, and then you go into another call, if gets overwritten?
You mean erase content while in a session or after the session is over?
There are quite a few scenarios here, if you could elaborate on your questions I might be able to give a more detailed answer.
/Magnus
Magnus Ohm
* call hung up
/Magnus
