SOLVED: Intermittent Proximity connection issues
chris.prime
I have seen multiple mentions about Proximity not connecting for some devices or intermittently on others and here's what I found today while troubleshooting my issue. I had to turn my sound bar up considerably before it would connect. I repeated the process multiple times with the exact same results. I assume different microphones, acoustics, distance from speakers, etc. all contribute to the connectivity issue. What it all came down to for me was getting a good sound connection between the speakers used by the VC unit and my computer microphone (pretty simple really). So, if you're having trouble connecting, try turning up the volume. I had to go from 15 to 30 on my sound bar before it worked. The good news is that once connected I was able to reduce it back to a normal volume without disconnecting.
Hope this helps!
Wayne DeNardi
On TC software based endpoints, there is a setting under the experimental section for the volume of the audio pairing that can be adjusted from 0 to 90 (default is 70).  THis can be increased without affecting the normal volume of the system.
Note: some sound bars and TVs are better at producing the pairing sound than others.  Make sure your speakers are capable of supporting up to 22kHz
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
