AS2511-RJ - NVRAM verification failed - want to try running different version of OS
marshallkelly
Hi, I suspect my terminal servers are no longer supported but I'm hoping to try to recover one that cannot remember it's config. The problem was detected when our lab was taken offline and physically moved across town.
The solution I was going to try is to load a different version of OS because I found that as a possible solution to a similar issue online. But I can't find a link to download the OS.
Am open to try other things if anyone has a different idea.
Thanks!
Marshall Kelly
Ribbon (formerly Genband) Communications
Router#write
Building configuration...
[OK]
NVRAM Verification Failed
Router#show version
IOS (tm) 2500 Software (C2500-I-L), Version 11.2(5)P, SHARED PLATFORM, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-1997 by cisco Systems, Inc.
Compiled Mon 07-Apr-97 11:52 by tej
Image text-base: 0x030229F8, data-base: 0x00001000
ROM: System Bootstrap, Version 11.0(10c)XB1, PLATFORM SPECIFIC RELEASE SOFTWARE (fc1)
ROM: 3000 Bootstrap Software (IGS-BOOT-R), Version 11.0(10c)XB1, PLATFORM SPECIFIC RELEASE SOFTWARE (fc1)
Router uptime is 3 days, 21 hours, 22 minutes
System restarted by power-on
System image file is "flash:c2500-i-l.112-5.P", booted via flash
cisco AS2511-RJ (68030) processor (revision I) with 2048K/2048K bytes of memory.
Processor board ID 08394789, with hardware revision 00000000
Bridging software.
X.25 software, Version 2.0, NET2, BFE and GOSIP compliant.
1 Ethernet/IEEE 802.3 interface(s)
1 Serial network interface(s)
16 terminal line(s)
32K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read ONLY)
21 Replies 21
Router(config)#service compress-config
Router(config)#boot ?
bootstrap Bootstrap image file
buffersize Specify the buffer size for netbooting a config file
host Router-specific config file
network Network-wide config file
system System image file
if write successful, reload and test the device is the config hold as expected.
also test
show run
show start
do you see both the command works as expected.
BB
Show run looks like expected but show start complains.
Router#show start
%% Non-volatile configuration memory has not been set up
try now copy run start or write memory
BB
I'm scared to get too optimistic but it actually looks like it's working now!
Thanks!
Router#write mem
Compressing configuration from 650 bytes to 476 bytes
[OK]
Router#copy run
Router#copy running-config st
Router#copy running-config startup-config
[OK]
Router#write mem
[OK]
balaji.bandi
If still an issue format and test it, also google some stable IOS the one was too old.
BB
Well I tried a reload and it lost the config again.
A subsequent write was successful but I tried it again and it is failing again.
Router#write
[OK]
Router#
Router#
Router#
Router#
Router#
Router#write mem
[OK]
I think I may run through the steps you indicated again. Maybe it's just time to replace this one.
Thanks for all your help. I will add an update after I retry - maybe tomorrow.
