bridge capability between a router port and a switched (L2) port (IOS XE)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
10-15-2018 08:31 AM
I am trying to set up a layer 2 bridge between a router port and a switched port on a 4321 router, running X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.5(3)S5. The switched port is located on a NIM-ES2-8 module. The router port is native.
This used to work properly on the former 2900 series, using bridge-group commands.
However, on the 4000 series, the bridge-group commands do not exist any more, and are replaced with 'service instance' commands.
While the 'service' command works as documented on router ports, it is not present on switched (L2) ports, even after issiuing the following commands as recommended in the documentation:
Switch (config)# switchport mode trunk
Switch (config)# switchport trunk allowed vlan none
Does anyone knows whether this feature exists on the 4000 series?
Many thanks for your help.
Dominique A.
- Labels:
Cisco Software
