Catalyst 6500 VSS - system uptime not reset after reload
lbenigni
I need to do a sanitary reboot for a cluster of Catalyst 6506 in VSS that have the uptime counter more than 3 years old.
I tested a procedure with the "redundancy force-switchover" command on both member alternatively, but at the end teh "show version" displays:
XXXXXXXXXXXXXX uptime is 3 years, 6 weeks, 3 days, 21 hours, 30 minutes
Uptime for this control processor is 13 hours, 33 minutes
System returned to ROM by Stateful Switchover at 22:01:32 METDST Sun Nov 6 2022
System restarted at 22:02:42 METDST Sun Nov 6 2022
I tested another cluster with the "reload" command and the system uptime counter was reset.
I've not tested the "redundancy reload shelf xx" command and I need to know if with that command I can reload both member alternatively and obtain the system uptime resetted.
Thank you
balaji.bandi
As per i know until both members go offline that time will not reset.
you can can check with below command give you when was the reloaded each device :
#show switch virtual redundancy
BB
Thank you Balaji.
Do you mean that even with the command "redundancy reload shelf xx" the system uptime counter is not reset?
The client has a server with a script that extracts from "show version" the uptime information for many network devices.
After the 6500 "sanitary reboot", the server will extract the uptime information.
I need to know if you, or someone else, can test the "redundancy reload shelf xx" command to see if the system uptime counter is reset or not.
