Cisco ISE Authentication issue in logs for Checkpoint
Secure_M10
I have my Checkpoint integrated with Cisco ISE 3.0 via RADIUS.. while i try to login to devices i am able to successfully login to CP Mgmt Center using AAA credentials but the ISE logs show authentication failure (Reason - incorrect password entered).. is it a known issue .. do i need to reset keys or anything for this ?
balaji.bandi
Do you have fall back with same username and password ?
BB
no ..fallback is only default "admin" user.. and the failed logs are getting triggered at exactly the same time while logging into the devices.
