Cisco wise connection
Brenno
Hi everyone, hope you're doing well!
I'm currently reviewing a solution that involves a captive portal for Wi-Fi authentication, and I’d really appreciate your input.
Does Cisco ISE support the following scenario?
"The web authentication portal should allow customization and support integration with authentication servers like AD, LDAP, and also a national single sign-on (SSO) platform that uses credentials such as a national ID and password. If direct integration isn't possible, alternative solutions that do not add extra cost to the overall system would be acceptable."
Specifically:
Can the ISE web portal be customized to this level?
Does ISE support integration with AD, LDAP, and SSO platforms using OAuth2/OIDC?
If not directly, is it possible to integrate a third-party access gateway or portal alongside ISE without needing additional paid modules?
Thanks a lot in advance for any guidance or experience you can share!
5 Replies 5
Enes Simnica
Level 5
Level 5
hello @Brenno Yes, Cisco ISE does support a high level of customization for web authentication portals, including branding, layout, and input fields. And absolutely u can design the captive portal to match national SSO branding or workflows, within certain limits.
Integration capabilities:
  • AD & LDAP: Fully supported out-of-the-box.
  • SSO using SAML is supported. However, OAuth2/OIDC is not natively supported for web authentication flows in ISE as of now.
If ur national SSO platform uses OAuth2/OIDC, direct integration with ISE’s captive portal won’t work. But u can place a third-party access gateway in front of ISE to handle SSO and then forward RADIUS accounting or CoA to ISE for policy enforcement. And its good to know that this doesn’t require additional ISE licenses, as long as u stay within Base/Plus tier features. Just avoid using features like pxGrid or profiling if u're trying to keep costs down.
check these links also: https://www.cisco.com/c/en/us/td/docs/security/ise/3-0/admin_guide/b_ISE_admin_3_0/b_ISE_admin_30_guest.html
https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/217457-configure-and-troubleshoot-external-web.html
hope the answer is not that long LOOOOOOL, good luck and hope it helps
-Enes
more Cisco?!
more Gym?!
If this post solved your problem, kindly mark it as Accepted Solution. Much appreciated!
Thanks @Enes Simnica, your answer helped me, but can you tell me some documentation that prove it?
good day to u @Brenno and glad it helped. Yes i do have some links that i believe will back up what i mentioned;
AND I FOUND THIS POST FROM @Jason Kunst which looks SICK!!! : https://community.cisco.com/t5/security-knowledge-base/ise-guest-access-prescriptive-deployment-guide/ta-p/3640475#toc-hId--1992631054
hope it helps and peace!
-Enes
more Cisco?!
more Gym?!
Can I know your requirements' forget what ISE support.
Maybe we can solve it by know excatly what your requirements.
You have user need to access network
This user must get portal write some info before access?
MHM
