EEM script issue while Backup on copy running-config startup-config
vishalsahu
Frequent Visitor
Frequent Visitor
Hello
I working an organisation. There I am using EEM script to take backup when any user put copy running-config startup-config command in Nexus switch. But I am getting error % command blocked by event manager policy. Below is the script for reference
event manager applet BACKUP_CONFIG
 Event cli match "copy running-config startup-config"
 action 1.0 cli command "copy running-config tftp://tftp-server/backup_config.txt"
action 2.0 syslog msg Backup copied successfully
Kindly help here
@TAC
14 Replies 14
 Event cli pattern "copy running-config startup-config" sync YES <- Sync Yes use if you want this command to run
MHM
In Nexus 9k  switch there is no that kind of command. Above mentioned cmd only there have. Can you suggest me how to bypass error with policy default. Earlier i read somewhere but I misplaced the post.
Already tried, But there i cannot override it. Might be Some argument have to pass on it
event manager applet applet-name override system-policy
here you need to know if you apply system-policy and it name
did you check you all config about the system-policy ?
MHM
I think this statement answer your Q
  • If you want to allow a triggered event to process any default actions, you must configure the EEM policy to allow the default action. For example, if you match a CLI command in a match statement, you must add the event-default action statement to the EEM policy or EEM will not allow the CLI command to execute.
r.heitmann
Level 5
Level 5
In some Cisco Nexus N9K-NXOS-Releases, there is a workaround needed to execute "critical" commands.
* usually it works in EEM-Applets to
a) "source out" the original command to a "cli alias" and
b) call that "alias" from the applet
similar to that:
conf t
  cli alias name wrbak copy running-config tftp://tftp-server/backup_config.txt
    no action 1.0
    action 1.0 cli command "wrbak"
end
Hello
I tried but nothing works. But I have remembered somewhere i find the solution for this by adding policy default cmd but I missed that post
did you add event-default
to event ?
MHM
Yes.
can I see the EEM after you add event-default
MHM
event manager applet FTPBackup
 event cli match "copy running-config startup-config"
 action 0.3 syslog msg "Backup started."
 action 0.5 cli command "enable"
 action 1.0 cli command "copy running-config ftp://user:password@ourserver.com/path/$(SWITCHNAME)_$(TIMESTAMP) vrf default"
 action 1.6 syslog msg "Backup ended."
 action 2.0 event-default
r.heitmann
Level 5
Level 5
I know - not what you might want, but would work out of the box:
* CLI-Alias with 2x commands instead of EEM:
cli alias name wr copy running-config startup-config ; copy running-config ftp://***FTPUSERNAME***:***FTPPASSWORD***@***FTPSERVERIP***/$(SWITCHNAME)-conf.$(TIMESTAMP) vrf default
Rebellious Geek
Community Member
Try putting the "event-default" as your first action. That solved it for me.
Initially, I had this setup and received the "% Command blocked by event manager policy" error:
event manager applet Switch-Config-Backup
description "Backup Running Config To FTP Server"
action 1.0 cli run-script bootflash:Switch-Config-Backup
However, when I reversed the actions as follows, the "copy run start" command ran without errors:
action 1.0 event-default
action 2.0 cli run-script bootflash:Switch-Config-Backup
My Switch-Config-Backup script contains the following line:
copy running-config ftp://<FTP-Username>:<FTP-Password>@<FTP-Server>/path/path/$(SWITCHNAME)/$(SWITCHNAME)---$(TIMESTAMP).txt vrf default
Hope this helps.
