i have a problem with opening Packet Tracer (MacOS m1 chip)
mihnea jerebnii
hello guys, i cannot open Packet Tracer anymore. So, I click on the application and it doesn't want to open. I uninstalled and installed Cisco Packet Tracer 8.2.1 many times
nbenslama
Did you find a solution to this problem, I am in the same situation and no solution found!
shkolatlen
I have the same problem, only restarting the system helps, but if you close the program again, you can't open it again without restarting the computer
Also even after opening the program creates a bunch of additional unnecessary processes and besides the main icon of the program in the bottom menu constantly flashes the same, that is, you have one packet tracer running and constantly blinking start another, it is very annoying
