02-28-2019 09:33 AM
Does anyone know or can point me to a doc. that states what the minimum firmware requirement is on a ISR4K router if we are going to upgrade to IOS 16.9.2?
Solved! Go to Solution.
02-28-2019 11:01 AM
check the table below for it:
for more information about: https://www.cisco.com/c/en/us/td/docs/routers/access/4400/release/xe-16-9/isr4k-rel-notes-xe-16-9.html#con_180601
03-01-2019 03:14 PM
02-28-2019 11:01 AM
02-28-2019 10:14 PM
03-01-2019 07:19 AM
I have hundreds of ISR4K that I all need upgrade. they are either running 3.x code with 15.x firmware or 16.x code running 16.x firmware.
03-01-2019 03:14 PM
