Minimum Firmware on ISR4K for 16.9.2 IOS
tporembski
Does anyone know or can point me to a doc.  that states what the minimum firmware requirement is on a ISR4K router  if we are going to upgrade to IOS 16.9.2?
2 Accepted Solutions
Jaderson Pessoa
check the table below for it:
for more information about: https://www.cisco.com/c/en/us/td/docs/routers/access/4400/release/xe-16-9/isr4k-rel-notes-xe-16-9.html#con_180601
Jaderson Pessoa
*** Rate All Helpful Responses ***
Pick a version and read the Release Notes carefully.
The Release Notes will have a detailed list of what model is/isn't supported.
Jaderson Pessoa
Jaderson Pessoa
Leo Laohoo
Minimum version???
Are you attempting to UPGRADE or DOWNGRADE?
I have hundreds of ISR4K that I all need upgrade. they are either running 3.x code with 15.x firmware or 16.x code running 16.x firmware.
