Networking Basics 14.3.3 Packet Tracer
MongSkyyy
I'm experiencing a stuck problem on the module I'm working on, did I make a mistake or am I still missing something?
My current position is stuck at 83%My current position is stuck at 83%
@MongSkyyy hi, this can be due to missing configurations as required by the activity, or mistake in marking criteria. try to check the configurations again to make sure that you completed all required configurations and if issue still persists, contact your instructor.
Good luck
KB
12 Replies 12
Good luck
KB
Thank you for helping bro
MongSkyyy
Thanks @MongSkyyy for the file
Best regards
@MongSkyyy
If you clic here:
You will see what you have to finish !
Best regards
Thank you for giving me the direction bro
M02@rt37
@MongSkyyy
Best regards
I have tried changing the IP address but there has been no improvement so far, maybe there are suggestions on how to solve it?
there's a mistake within the wizard configurations ( state-h implemented instead of finance-h ) for the IP value check for the Finance 2 PC. ++
david-villam50
tengo el mismo problema alguna solución ?
hay un error en la redacción del ejercicio. debe corregir el error utilizando la herramienta del asistente de creación de ejercicios y luego guardar. debes reemplazar "state-h" por "finance-h" en los sondeos DHCP para el valor de la IP de la PC "Finance 2"
Bcp CIEL
Hi !
I've founded the solution. there's a mistake when the activity was implemented. the DHCP pool checked for the result is not the good one. so as you can see below i've made the correction and know i get a 100%. go on the wizard tool ++
