Networking Basics 14.3.3 Packet Tracer
MongSkyyy
I'm experiencing a stuck problem on the module I'm working on, did I make a mistake or am I still missing something?
My current position is stuck at 83%My current position is stuck at 83%
@MongSkyyy hi, this can be due to missing configurations as required by the activity, or mistake in marking criteria. try to check the configurations again to make sure that you completed all required configurations and if issue still persists, contact your instructor.
Good luck
KB
9 Replies 9
Good luck
KB
Thank you for helping bro
MongSkyyy
Thanks @MongSkyyy for the file
Best regards
@MongSkyyy
If you clic here:
You will see what you have to finish !
Best regards
Thank you for giving me the direction bro
M02@rt37
@MongSkyyy
Best regards
I have tried changing the IP address but there has been no improvement so far, maybe there are suggestions on how to solve it?
david-villam50
tengo el mismo problema alguna solución ?
