01-17-2023 07:39 AM - edited 01-18-2023 10:26 PM
If you have issues with Expressways (connecting to site https://smartreceiver.cisco.com/licservice/license ), you are not alone and Cisco is already working on it.
Please open SRs anyway to raise awareness.
Apparently there was a Certification change on the 14th.
Impact:
New Expressway Series deployment / existing deployment where you need to register Expressway to Smart Licensing: NOT POSSIBLE to register to Smart Licensing
Existing Expressway Series already registered to Smart Licensing: a tremendous amount of error logs entries SmartAgentNotifyAuthRenewFailure and SmartAgentNotifyCommFailure
02-06-2023 05:45 AM
07-28-2023 10:33 AM
Exwy with X14.2.7 - issue still present. New case opened.
02-14-2023 06:53 AM
02-18-2023 09:43 AM
has anyone loaded / installed 14.2.5 yet, my team plans to load on production expressways next week .... fingers crossed
02-18-2023 10:45 AM - edited 02-18-2023 10:46 AM
I've installed it on two different environments. One thing I have noticed is MRA just flat out doesn't work after the initial install. I have to perform another restart on the C and E before it began working. It's completely stable after that though. I've seen that on all X14.2 upgrades I've performed though, not just X14.2.5. Direct connection smart licensing worked on both environments without issue post upgrade.
Something TAC told me prior to the release, and I verified as well via one of the environments, is MRA continued to function after the evaluation period ended. Phones registered with CUCM via MRA without an issue since MRA doesn't need any licenses to work.
07-06-2023 09:23 AM
14.2.5 and 14.0.11 have the fix for this bug / issue.
07-28-2023 11:29 AM
I have 3 clusters on 14.2.6 and have no issues with my many MRA users or and smart licensing.
