USB for upgrade ASR 1000
Hello
I am planing to upgrade an ASR 1000 using USB drive.
I read online that the USB stick needs special preparation but i didnt find anything on CISCO website on how.
Would someone refere me to the right direction please?
and Thanks
saravanan93
Hi Amhish,
Please follow the following steps to copy IOS to routers via USB
*have a USB stick with version 2.0 (version 3.0 won't support for all model router)
*copy the IOS to USB
* insert USB on router
* check the router able detect USB
*copy usb:(IOS file name ) flash:
* once IOS copy to flash
* set boot command to router on golbal configuration mode
* boot system bootflash:/(IOS file name)
thanks
saravanan
6 Replies 6
saravanan93
Hi Amhish,
thanks
saravanan
Thank you for your ansewer .
Your way works definitely.
and i did find a way to take any USB and turn it to be used with CISCO ASR 1000 router.
steps:
1- Partition your USB to 1-2 GB
2-Make that Partition Primary (and only Partition on the USB ,that means you will have unused space)
3-fat format FAT16 with clustersize 32KB.
4-make sure your USB ist USB1.1 compatible.
5-enjoy.
Leo Laohoo
Make sure the USB stick is supported by the router.
Plug the stick into the router and, if supported, format the stick (Command: format usb0:).
After only the stick has been formatted do you add files into it.
Hello
How to know if the USB is supported by the Router?
Best regards
Amr Mhish
Plug the USB thumb drive into the router. The "sh log" will have entries to determine if the router will support the USB thumb drive or not.
insert USB stick into the router
Router# dir usb:
check whether able see the file in USB stick
