Using a personal vpn before connecting to Cisco secure mobility client
Cherrihassan
Hi community
My question is if I open my own VPN before connecting to the Cisco VPN secure mobility client will I have any problem with connection or Will not be a problem at all using two VPNs at the same time?
Example I open NordVPN that is my personal VPN on my computer before connecting to the Eco VPN secure the client, Would pose any problem for connection??
5 Replies 5
balaji.bandi
Good question - never tried (may be trying to high where you login to work using remote Location) - good idea.
If the Router available to reach your corporate VPN technically should work.
BB
All I want to do I that Cisco vpn connect from my company doesn’t see that I’m outside Montreal, how often down Cisco take your ip during the day? Maybe the solution is to open my personal vpn before the Cisco vpn, and then once I activate Cisco vpn I disconnect my personal vpn as maybe Cisco only take one time your ip during session ? What should I do
May be you need between another device where the NordVPN connected already, and you connect that device to that device and connect to VPN.
I have this travel Wifi Router that solved your problem (if you can able to get one)
GL.iNet GL-MT3000 (Beryl AX)
BB
WoW basically saying that if I go to Colombia, who is this router (GL.iNet GL-MT3000) that have a open source VPN inside and then I connected to the computer provided for my company that uses Cisco VPN they won’t know I’m outside Montreal ?
yes correct i used many times when i was travelling to abroad, not to connect VPN, that Router connect to My Home, so i can access Home directly connecting that Router.
BB
