03-20-2020 06:33 PM
Hi All,
I downloaded image from CISCO site and when i did md5 verification for new ios 156.2.SP7 , it doesn't match with CISCO given signature. I tried it twice but still doesn't match.
I have used verify /md5 me380x-universalk9-mz.156-2.SP7.bin
Does this mean IOS on cisco site is corrupt?
Solved! Go to Solution.
03-20-2020 07:44 PM - edited 03-20-2020 07:45 PM
What did you download from Cisco? Cisco site has the .tar file but on the router you are verifying the .bin file. If you want to verify the .bin file, then untar the file on your computer and verify the .bin. If you have a Windows PC, you can download and use the "Microsoft File Checksum Integrity Verifier". For Linux you can use "md5sum"
John
03-20-2020 07:48 PM
03-20-2020 06:40 PM
03-20-2020 06:43 PM
John
03-20-2020 07:48 PM
03-20-2020 07:52 PM
yes, archive download-sw.
finally sorted .
md5 on cisco site was for tar and when I did same for TAR - verified.
Initially I was checking tar with bin signature and wondering why is it coming different.
Thanks a lot Tech Guru's for your quick response.
03-20-2020 07:54 PM
