Web Gui not working following flash to sdflash IOS sync
maryannconnor
I'm having an issue with a ie4010 switch where I update the firmware on the switch itself to 15.2(8)E6 from 15.2(8)E1,
The switch boots from the SD card and so following the firmware update I tried a full sync from flash to sdflash including the IOS image to complete the update process,
But when the sync has been running for a few minutes the web GUI is not accessible and the firmware reverts to the SD firmware, even though it is the 'Synchronize IOS image from Onboard flash to SD card'
Following a power cycle the web gui is back but the switch reverts to the firmware before the updates (same as SD card)
I have also tried doing it through cli using 'sync flash: sdflash:' and had the same outcome
Any suggestions would be appreciated!
0 Replies 0
