ā07-27-2023 05:48 AM
I am at a complete loss as a newbie š¤¦āāļø
I bought the Cisco SG200-50port with PoE. I have reset the router and connected the switch to the computer but I canāt access the GUI as the error appears either timed out or no internet access. I just donāt know what I am doing wrong and google/YouTube just donāt seem to have the answers. Any help will be greatly appreciated šŖ
ā07-27-2023 06:07 AM
@jamiemckabab after reset switch automatically use default IP. check below guide for initial setup.
ā07-27-2023 06:20 AM
I have done all that but it still isnāt allowing me to get too the GUI š„² itās proven to be quiet difficult. It shows when I do an IPCONFIG/ALL but if I attempt to ping etc it does respond š¤¦āāļø I am at a loss with what to do now. Thank you for the reply
ā07-27-2023 09:00 AM - edited ā07-27-2023 09:00 AM
You should have this basic config in order to access the device. Of course the IP address showing here are just examples
ā07-27-2023 09:24 AM
I canāt get that far with itā¦. I plug it in and then nothing the Ethernet port doesnāt notice itās an internet connection for most of the time. So I canāt even connect to the switch properly. I have reset it multiple times, removed the power plug aswell multiple times for what I hoped would be a way to fix any issues with reset. The power led is continually flashing and if I plug an Ethernet into the act/link it flickers ie saying that thereās activity happening
ā07-27-2023 10:07 AM
If you add an IP address on your PC on the network 192.168.1.0/24 , for example, 192.168.1.1, you plug a cable from your PC to the switch port and open a web browser and issued: http://192.168.1.254
And you get nothing, you may have a faulty switch in your hands.
ā07-27-2023 10:13 AM
Iām really sorry but what do you mean add an IP address on the PC? I know this is a basic network question but I usally have unmanaged switch š¤¦āāļø thanks for the input
ā07-27-2023 10:22 AM - edited ā07-27-2023 10:23 AM
Dont feel sorry @jamiemckabab it is fine not to know this if you dont need to.
Add a IP Address on the computer is pretty simple. I will give you a step by step considering Windows but if you use a different Operating system, we can find also.
https://www.youtube.com/watch?v=5iRp1Nug0PU
ā07-27-2023 10:28 AM
Yipe thatās the one I followed but Iāve been unable to save for some reason? I will attempt this again though and get back to you thank you
ā07-27-2023 10:29 AM
I share a video but it upload another thing. Just make sure you are administrator of the PC, you need to be.
ā07-27-2023 10:42 AM
Followed both links ( Iām currently using windows 11 ) I added the subnet mask etc and itās just not allowing me to access the switch at all. Iām still not getting an internet connection either whilst plugged into the switch? My brain is frazzled with it š¤¦āāļø
ā07-27-2023 10:46 AM
I am the administrator on the PC I downloaded Advanced IP Scanner which it shows the device but when I ping it it stays destination host unreachable?
ā07-27-2023 10:57 AM
Som you managed to add IP add on the PC?
What you can do is reset the switch.
The switch might also have a reset button. The switch can be reset by
inserting a pin or paper clip into the reset opening.
If the switch have a different IP than 192.168.1.254, by reseting it, the IP address must return to 192.168.1.254
ā07-27-2023 11:00 AM - edited ā07-27-2023 11:00 AM
Thatās the IP address I attempted too add, I entered the submask etc and used google as a back up DNS ( 8.8.8.8 ) but again I have been unable too save the IP address ( using IP4v ) again I would like to thank you for your time and input on this confusing matter š¤¦āāļø
ā07-27-2023 11:10 AM
If you have a wifi router over there, you might be able to connect the PC to the router interface and the switch to the router interface and use the DHCP provided by the router. Then, using you Scanner and find the IP the switch got.
