ā07-27-2023 05:48 AM
I am at a complete loss as a newbie š¤¦āāļø
I bought the Cisco SG200-50port with PoE. I have reset the router and connected the switch to the computer but I canāt access the GUI as the error appears either timed out or no internet access. I just donāt know what I am doing wrong and google/YouTube just donāt seem to have the answers. Any help will be greatly appreciated šŖ
ā07-27-2023 11:15 AM
The switch has the IP you posted previously so I am finding the switchās default IP address but thatās as far as Iām able to go with it. Got the submask as well of course, Iāve connected to the router/modem combi and made sure that was the right IP address. Itās as soon as I type it into the address bar it simply does not connect too the internet or gives a timed out error
ā07-27-2023 11:21 AM
If you are using your local router, the IP address I mentioned will not work as it will be different from the IP address on your router.
If you are using the router to get IP address, try to reset the switch and make sure it gets an IP address on the same network as your PC.
