configuration save
what is the difference between save configuration ?
# copy running-config startup config
                                         Or
#copy run start
                                     Or
#wr
Leo Laohoo
                                         Or
#copy run start
                                     Or
#wr
If you are taking your CCNA/CCNP/CCIE exam, the command "write" is not supported.
The "write" command is also not officially a supported command in Nexus.
outcome of All commands are same thing.
Good luck
KB
