Not able to login XSI with SIP credential
My phone has no problem to login to XSI server with XSI username and password
However please see attached capture that my phone tries to login to XSI server withSIP credential but gets 401 unauthorized response.
Is this a Broadsoft DevNet server issue?
7 Replies 7
skumar1
Level 3
Level 3
Guy,
Did you created a device profile instance for the user with custom user/pwd?
Please provide me the device profile and user informtation, I will take a look.
Hi skumar,
My device profile is Generic_SIP.  The user is 9736722307
This capture shows my phone can login XSI with custom password
any update on this issue?
Guy,
can you let me know the test case you are referring to? For XSI test cases I believe we need to have device specific profile instances.
Hi skumar1,
This is not specific Interop testcase.  I want to verify DUT can login to XSI with SIP credential and able to retrieve Broadsoft directories.
I don't recall it needs "device specific profile instances" for XSI directories.
With just "Generic_SIP" profile instance, my phone can retrieve broadsoft directories custom password though.
If it really need "device specific profile instances", can you help to setup the profile in my sandbox?
Guy,
Please try again now. It should be working.
