how to read the data from webex using informatica
pnallapati
Community Member
we are trying to integrate webex data to our salesforce. i have downloaded the schema files. i cant see the custom fields.
how to read the custom field information.
mifierro
Level 6
Level 6
Greetings, Prasad! Are you experiencing these difficulties when trying to use Salesforce to import the data, or a WebEx API to export it?
kinglewi
Hi Prasad,
It depends on what custom fields you are looking for.  Webex supports tracking codes at both the user and the meeting level.  These can be returned with GetUser for the user level, or GetMeeting at the meeting/scheduling level.  If you need more information on custom fields please reply back with more details on which custom fields you are specifically looking for.
Thank you,
