Issue with getSiteType
nick.mueller
Level 10
Level 10
I can't seem to get the "getSiteType" API to work for me.
The API was introduced with 9.0: https://developer.cisco.com/site/webex-developer/develop-test/xml-api/reference/release-notes-9-0.gsp#mozTocId110632
It is of course possible that I am doing something wrong.
I am posting to this URL (replacing "site" with the site name):  https://site.webex.com/WBXService/XMLService
I am posting this XML (again, replacing "site" with just the first (host) portion of the sitename, not the full FQDN "site.webex.com"):
<?xml version="1.0" encoding="UTF-8"?>
<serv:message xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:serv="http://www.webex.com/schemas/2002/06/service">
<header>
<securitycontext>
<sitename>site</sitename>
</securitycontext>
</header>
<body>
<bodycontent xsi:type="java:com.webex.service.binding.ep.GetSiteType"></bodycontent>
</body>
</serv:message>
Here is what I get in reply:
<serv:message xmlns:serv="http://www.webex.com/schemas/2002/06/service" xmlns:com="http://www.webex.com/schemas/2002/06/common">
<serv:header>
<serv:response>
<serv:result>FAILURE</serv:result>
<serv:reason>Fail to forward request:null</serv:reason>
<serv:gsbStatus>PRIMARY</serv:gsbStatus>
<serv:exceptionID>000000</serv:exceptionID></serv:response>
</serv:header>
<serv:body>
</serv:body>
</serv:message>
Can anyone shed some light on this?
NPM
kasutton
Hi Nick,
I tested this out and confirmed it's because the elements in the securityContext were not the correct case. In correcting just those, it resolves that error and introduces a new error, "validation: unable to find FieldDescriptor for 'bodycontent' in ClassDescriptor of body" which is resolved by correcting the case for bodyContent.  Working XML request is below:
  <header>
    <securityContext>
      <siteName>sitename</siteName>
    </securityContext>
  </header>
  <body>
    <bodyContent xsi:type="java:com.webex.service.binding.ep.GetSiteType">
    </bodyContent>
  </body>
</serv:message>
Kasey
kasutton
Hi Nick,
  <header>
    <securityContext>
    </securityContext>
  </header>
  <body>
    </bodyContent>
  </body>
</serv:message>
Kasey
Thanks Kasey.
I took my example XML directly from the release notes I linked above.  Those release notes should be corrected.
Also this API is not documented in the XML API documentation on DevNet - could that oversight please be corrected?
NPM
Hi Nick,
I'll see what I can do about getting it corrected. Thanks for bringing it to our attention.
Kasey
Will this API ever make it into the XML API Reference on DevNet?
