WebEx SSO with ADFS 2.0 - External Connection fails
CHRIS KALETH
Level 5
Level 5
We have successfully configured SSO with WebEx and our ADFS 2.0 environment but it only works when we are in the office or connected to VPN.  When I click "host login" outside of our network I get the following error: Error: Reason:  Invalid SAML Assertion (13).  Thoughts?
kinglewi
The following support knowledge base article will have more information on this issue.  http://kb.webex.com/WBX54373.
The error indicates they have you may have the incorrect AuthnContextClassRef, which can be different if going through a proxy or if the account is external. To work around this problem WebEx will allow you to set multiple AuthnContextClassRefs on the WebEx site admin page that are separated by a semicolon It would look something like this
urn:federation:authentication:windows;urn:oasis:names:tc:SAML:2.0:ac:classes:Password
if you do not know what the value is for external users, I would try the above suggestion first.
You can also try the following AuthnContextClassRef values:
urn:oasis:names:tc:SAML:2.0:ac:classes:PasswordProtectedTransport
urn:oasis:names:tc:SAML:2.0:ac:classes:Kerberos
If it still fails then we will need to see the assertion for one of the outside connection which is failing with the error 13.
kinglewi
Perfect!  That did the trick.
Previous Config:  urn:federation:authentication:windows
New Config: urn:federation:authentication:windows;urn:oasis:names:tc:SAML:2.0:ac:classes:PasswordProtectedTransport
