What is a difference between meeting types and supported services.
anand_dhage
I tried to get user details from below endpoint
<bodyContent xsi:type="java:com.webex.service.binding.user.GetUser">
In response i got all the details of user including supportedServices  and  meeting type block
<use:supportedServices>
     <use:meetingCenter>false</use:meetingCenter>
     <use:trainingCenter>true</use:trainingCenter>
     <use:supportCenter>true</use:supportCenter>
      <use:eventCenter>false</use:eventCenter>
      <use:salesCenter>false</use:salesCenter>
</use:supportedServices>
<use:meetingTypes>
     <use:meetingType>220</use:meetingType>
     <use:meetingType>564</use:meetingType>
</use:meetingTypes>
What is a difference between supportedServices and meetingTypes block?
What it indicate?
kasutton
Hi Anand,
supportedServices is a more general setting that controls whether a user has access to an entire service (ie. Meeting Center). meetingTypes is an explicit setting that controls which specific meetingTypes a user has access to. For instance, if you have Training Center enabled on the site, you may have one standard meeting/session type that is default (created by WebEx) and one custom session type that you based off of that standard session type (for example, a custom session type that is identical to the standard one, but has Network Based Recording disabled). In this case, you could give a host access to the custom session type if you don't want them to be able to record. Hope that makes sense.
Kasey
kasutton
Hi Anand,
Kasey
Thank you Kasey for your help.
