Configuration Sync Not Loading - Workaround
mloraditch
Meraki Community All-Star
Had to call support on this as configuration sync was not loading for any org. It's a known bug with the recent gui changes and no fix eta.
Figured I'd share the workaround:
This can be worked around by appending the URL with "?show_new_side_navigation=false" or "&show_new_side_navigation=false"
The first is if your URL has no parameters and the second is if there are any parameters already present.
Example:
https://nXXX.dashboard.meraki.com/o/SXX/manage/organization/bulk_editor?show_new_side_navigation=false
https://nXXX.dashboard.meraki.com/o/SXXXc/manage/organization/bulk_editor?from=organization+configuration-sync&show_new_side_navigation=false
If you found this post helpful, please give it a thumbs up. If my answer solves your problem please click Accept as Solution so others can benefit from it.
Raphael_L
Thanks for the heads up !
Does this apply to any config ?
mloraditch
I believe so.
