Dark mode bugs
CMR
Meraki Community All-Star
I thought I'd start a thread about the various (often minor) dark mode bugs that still need sorting out. Please feel free to add any you find and hopefully we will get some developers reading this!
If my answer solves your problem please click Accept as Solution so others can benefit from it.
spaladug
Meraki Employee All-Star
@CMR I've brought all the above issues up to engineering soon after you started the thread and its just a matter of prioritizing them. Thanks again for sharing all those.
89 Replies 89
CMR
In the Insight / WAN Health page, you can choose what you monitor, but in dark mode it is a bit of a guess:
spaladug
@CMR Good news. The fix for this has been pushed out and I have validated it (attached pic).
CMR
Thank you @spaladug !!
CMR
Whenever the help centre pops up, it is stubbornly in light mode:
RWelch-USA
 @spaladug - it looks like there have been some dashboard upgrades/improvements specifically the L column.
Has anyone mentioned that "sometimes" the full layout doesn't always populate seen above - trying to select
Configure > Addressing & VLANs (not visible)?
Other times it works ok as seen below (and yes, I've tried different browsers)
Hi @RWelch-USA . I'm not able to reproduce that issue you highlighted, but I can say that it's at least not related to the new dark mode theme.
If you are able to reproduce it reliably, please open a case with Meraki support and feel free to DM me the case number so I can follow up on it.
dunky
Level 9
Level 9
When doing a pcap for a switchport and viewing the output live, its white on white, have to select to be able to read it.
spaladug
@steve.prescott Engineering just pushed out the fix for this today and I've confirmed it is resolved now. Attached pic for reference.
jvaldez2
@CMR this legacy widget was fully replaced last month by a new Get Help workflow that leverages the AI Assistant and it correctly respects the dark mode preference.
CMR
When the dashboard times out the reminder that your session is about to expire is dark, but when you click to continue, you are greeted with this:
dunky
Level 9
Level 9
Im not logged in at present but i recall when working with firewall rules if enter a policy object ir IP that has an object, the potential objects that are displayed are virtually unreadable - white on grey i think.
spaladug
@steve.prescott this was resolved on Jan 14th.
Thanks, I can see that's now resolved 🙂
JamesGill5290
Level 3
Level 3
The banner for templated networks still shows the brown banner.
