Dark mode bugs
CMR
Meraki Community All-Star
I thought I'd start a thread about the various (often minor) dark mode bugs that still need sorting out. Please feel free to add any you find and hopefully we will get some developers reading this!
If my answer solves your problem please click Accept as Solution so others can benefit from it.
89 Replies 89
MarcP829
Level 9
Level 9
Deleting a Network, the confimration button looks like this, after ticking the checkbox:
Should be:
spaladug
Meraki Employee All-Star
@MarcP829 Good news is that engineering pushed out the fix yesterday and I have confirmed it is resolved now. Attached pics of how it now looks before and after the checkbox is selected.
dunky
Level 9
Level 9
And another....
Go to a client page that's on WiFi and click on the Performance tab at the top.
When hovering over items its white on grey and unreadable....
spaladug
@dunky I'm not able to reproduce that issue. Attached what I see on that page which is looking as expected. Please open a Meraki Support case so it can be triaged.
CMR
@dunky it also works for me in the same way @spaladug showed.  I am using Edge, what browser gives you the bad version?
@CMR I'm using Edge too.  I'll open a case as @spaladug suggested.
dunky
Level 9
Level 9
Org>API & Webhooks is showing white on white for me....
spaladug
@dunky I am not able to reproduce that issue. Attached pic below of how it looks for me. This is the second time you are seeing behavior inconsistent with me. Do you see the issue with other browsers or a private window in Edge? Wondering if there is some caching issue with that respective browser session.
@spaladug Looks like there is summat wrong with my Edge browser - all works fine in Chrome so I've changed to using that for the Dashboard.  Thanks
CMR
PCI report is somewhat unreadable...:
spaladug
@CMR Thanks for bringing this up. I was able to reproduce this issue and have notified engineering about the issue.
spaladug
@CMR Good news as the fix for this issue was pushed out today and the page is now looking good on dark mode.
dunky
Level 9
Level 9
Another bug...
In a camera-only network under Cameras-General, there are two boxes with white on white, meaning have to highlight in order to be able to read them:
spaladug
@dunky Thanks for bringing this up. I was able to reproduce this issue and have notified engineering about the issue. Will circle back once I have an update.
dunky
Level 9
Level 9
And another...
When on the Firewall page, it's impossible to see if Inbound firewall logging is enabled or disabled:
but if you flip into light mode you can see properly:
