MX67 fail to upgrade
After removing a MX67 running MX17.3 from a network in Dashboard - no psysical movement or disconnets, then I added the device into a new created network - a downgrade to MX15.44 happend.
The device are fuctioning well, but I need to use AnyConnect therefore at least MX16.xx is required.
When I try to upgrade, the I got the following message:
here were errors in saving this configuration:
What to do?
Best regards,
Michael
Ryan_Miles
Meraki Employee All-Star
This error will likely clear after some time on its own. However, I can push the upgrade immediately if you need it resolved ASAP. If interested just direct message me the MX serial number.
5 Replies 5
Ryan_Miles
Perfect - thankt you - I'll send you the serial number in minutes 🙂
Br,
Michael
Hello rymiles. I have a similar issue and I have been waiting to get feedback for over 48 hours which is very exhausting. Can you help push the upgrade immediately?
Ryan_Miles
DM me your org link
it@sportler.com
Frequent Visitor
Frequent Visitor
Hi Ryan, i have this probleme also but in templates. If the fw is outside template no error....
