Sort of...
CMR
Meraki Community All-Star
When looking at the new clients view, you are able to sort by Capable Wi-Fi standards, or at least it gives the pretence that you can do so. As you can see below from a sample network, it is absolutely not sorted at all... Doh! Come on Meraki, you can do better than this!
If my answer solves your problem please click Accept as Solution so others can benefit from it.
BlakeRichardson
Export to CSV is your friend in this instance 🤣
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
6 Replies 6
CMR
It applies to many of the columns, here is capable channel width where the choices are much simpler to sort...
Raphael_L
I have reported similar issues months ago. Am I surprised to see more sorting issues ? 😶
RWelch-USA
Sort of...😂🤣😂
BlakeRichardson
CMR
For now I fear you have offered the best solution! 😂
BlakeRichardson
Have you checked to see if there is any difference between the old and new dashboard in terms of how they sort?
