Bookmark
Subscribe
2765
Ansible Logging Outout
Netmart
Level 3
Level 3
To my understanding, the output will be printed on the screen.
I would like save it under a log file.
I tried to add it to ansible.cfg file, but still I am not able to see the log file:
[default]
#some basic default values...
nocows=true
#log_path=/etc/ansible/logs/ansible_log.txt
log_path=./ansible_log.txt
callbacks_enabled=ansible.posix.profile_tasks
stdout_callback=ansible.posix.json
inventory      = $HOME/.ansible/hosts
remote_tmp     = $HOME/.ansible/tmp
forks          = 150
sudo_user      = root
transport      = smart
host_key_checking = False
Netmart
Thank you Marcel.
Eventually I used:
  tasks:
     - name: show license all
       ios_command:
          commands:
              - terminal length 0
              - terminal width 200
              - show license status
       become: true
       register: output
     - name: print result
       debug:
          var: output
And directed the output to a text file:
ansible-playbook -i hosts site-iosxe-lic-enable-vault.yml -u cisco-k > site-iosxe-lic.txt
ass
6 Replies 6
Marcel Zehnder
Hi, the log_path directive is correct. See this basic example:
ansible.cfg
[defaults]
log_path=./ansible.log
playbook (test.yml)
- name: test logging
  hosts: localhost
  gather_facts: false
  tasks:
    - name: a test debug message
      ansible.builtin.debug:
        msg: "This is a debug ouput"
this will create a log file ansible.log with the following content:
maercu@CHLT303344:~/dev/tmp$ cat ansible.log
2023-09-11 07:58:11,656 p=699 u=maercu n=ansible | [WARNING]: No inventory was parsed, only implicit localhost is available
2023-09-11 07:58:11,660 p=699 u=maercu n=ansible | [WARNING]: provided hosts list is empty, only localhost is available. Note that the implicit localhost does not match 'all'
2023-09-11 07:58:11,765 p=699 u=maercu n=ansible | PLAY [test logging] ***************************************************************************************************************************************
2023-09-11 07:58:11,776 p=699 u=maercu n=ansible | TASK [a test debug message] *******************************************************************************************************************************
2023-09-11 07:58:11,789 p=699 u=maercu n=ansible | ok: [localhost] => {
    "msg": "This is a debug ouput"
2023-09-11 07:58:11,796 p=699 u=maercu n=ansible | PLAY RECAP ************************************************************************************************************************************************
2023-09-11 07:58:11,796 p=699 u=maercu n=ansible | localhost                  : ok=1    changed=0    unreachable=0    failed=0    skipped=0    rescued=0    ignored=0
Thank you Marcel.
I tried and got the following in the logs:
$ cat ansible.log
2023-09-11 07:58:11,656 p=699 u=cisco n=ansible | [WARNING]: No inventory was parsed, only implicit localhost is available
2023-09-11 07:58:11,660 p=699 u=cisco n=ansible | [WARNING]: provided hosts list is empty, only localhost is available. Note that the implicit localhost does not match 'all'
2023-09-11 07:58:11,765 p=699 u=cisco n=ansible | PLAY [test logging] ***************************************************************************************************************************************
2023-09-11 07:58:11,776 p=699 u=cisco n=ansible | TASK [a test debug message] *******************************************************************************************************************************
2023-09-11 07:58:11,789 p=699 u=cisco n=ansible | ok: [localhost] => {
2023-09-11 07:58:11,796 p=699 u=cisco n=ansible | PLAY RECAP ************************************************************************************************************************************************
2023-09-11 07:58:11,796 p=699 u=cisco n=ansible | localhost                  : ok=1    changed=0    unreachable=0    failed=0    skipped=0    rescued=0    ignored=0
My goal was to capture the show output of the following runbook. So not sure, if this does require a different type of logging:
site.yml file
- name: Test Ansible ios_command on Cisco IOS XE
  hosts: iosxe
  tasks:
     - name: show version and ip interface brief
       ios_command:
          commands:
              - show version
              - show ip interface brief
I would appreciate any advice.
Netmart
In that case you need to register and print (debug) the result of your task - something like that:
  hosts: iosxe
  tasks:
        ios_command:
          commands:
              - show version
        register: output
        debug:
          var: output.stdout
Doing so, you should see the output on screen as well as in your log file.
Thank you Marcel.
Yes, it does print output on screen plus append it to ansible.log file
Is it possible to save the output as separated file as txt, yaml, or even json.
Also, when I tried to run "show license feature", it seems that the loaded ansible collect is not support it.
  tasks:
     - name: show license feature
       ios_command:
          commands:
              - show license feature
*fatal: [10.254.199.199]: FAILED! => {"ansible_facts": {}, "changed": false, "failed_modules": {"ansible.legacy.ios_facts": {"failed": true, "invocation": {"module_args": {"available_network_resources": false, "gather_network_resources": null, "gather_subset": ["min"]}}, "msg": "ssh connection failed: Failed to authenticate public key: Socket error: disconnected"}}, "msg": "The following modules failed to execute: ansible.legacy.ios_facts\n"}
Marcel Zehnder
The error you receive is because of the host key checking (https://docs.ansible.com/ansible/2.8/user_guide/intro_getting_started.html#host-key-checking), to disable it, disable host key checking in your ansible.cfg:
[defaults]
To collect json parsed output, I usually use the cli_parse module (https://docs.ansible.com/ansible/latest/collections/ansible/utils/cli_parse_module.html) with pyats/genie, to use it you may need to install the collection + libary:
ansible-galaxy collection install ansible.utils
pip install pyats
Once done you can use it, here is an example:
inentory
all:
  hosts:
    sandbox-iosxe-latest-1.cisco.com:
  vars:
    ansible_user: admin
    ansible_password: C1sco12345
    ansible_network_os: cisco.ios.ios
    ansible_connection: ansible.netcommon.network_cli
playbook
- name: Log outputs to file
  hosts: sandbox-iosxe-latest-1.cisco.com
  gather_facts: false
  tasks:
    ### GET AND SAVE TXT OUTPUT #########################
    - name: Run command
      cisco.ios.ios_command:
        commands:
          - show license usage
      register: output
    - name: Print result as txt
      debug:
        var: output.stdout[0]
    - name: Save result as txt to file hostname_output.txt
      ansible.builtin.copy:
        content: "{{output.stdout[0]}}"
        dest: "{{inventory_hostname}}_output.txt"
    ### GET AND SAVE JSON OUTPUT ########################
    - name: Run command and parse with genie
      ansible.utils.cli_parse:
        command: show license usage
        parser:
      register: output
    - name: Print Result as json
        var: output.parsed
    - name: Save result as json to file hostname_output.json
        content: "{{output.parsed}}"
        dest: "{{inventory_hostname}}_output.json"
Thank you Marcel.
Eventually I used:
  tasks:
       ios_command:
          commands:
              - terminal length 0
       become: true
       register: output
       debug:
          var: output
ass
