Ansible Wait for Ouput - ansible.builtin.wait_for module
Netmart
I am working on a Metric check list including show commands.
Some of those commands provide output with a delay or even require to hit "enter" to scroll further down.
I was wondering, what the best approach would be to tackle this issue.
Not sure if the following module would be the proper approach:
     - name: Task30 sh version  installed
       ios_command:
          commands:
              - sh version installed
Ok, I think I solved it by also changig the timeout.
Now, Ansible is waiting until command output and captures the whole output of " show version installed"
# Example – show version installed on Cisco Cat9k
- name: Ansible site-ios-xe-L2-L3-Metrics-Check-IDF_@M.Wolf_Jan2024
  hosts: MTIDFiosxe
  vars_files:
         - /home/wolfm/Ansible/vault_password.yml
  vars:
      ansible_become_pass: "{{ vault_sudo_password }}"
      ansible_python_interpreter: /usr/bin/python3
      ansible_command_timeout: 120
       ios_command:
          commands: sh version installed
          wait_for: result[0] contains Provisioning File
- name: Task30 sh version install install after upgrade
       debug:
          var: output30
Ruben Cocheno
@Netmart
Yes, an example
- name: Run show version and check to see if output contains IOS
  cisco.ios.ios_command:
    commands: show version
    wait_for: result[0] contains IOS
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
Thank you Ruben.
There is one more challenge.
If show command requires to hit enter for "more".
For example "sh version installed" requires to hit more to scroll down.
Please advise.
Thanks.
  hosts: MTIDFiosxe
  vars_files:
  vars:
       ios_command:
       debug:
          var: output30
