Alternate voicemail solution for CME
Hi ,
We are in the process of deploying CME ver 14.0 , as per cisco CUE (module)  is obsolete, also CUE Virtual EOS / EOL lin 2023.
Cisco recommends going with Cisco unity connection but our UCS servers are too old, we don't want to reuse it.
Looking for other alternate voicemail solutions for CME
Hi Mohamed,
You don't always require UCS servers to have the unity connection, you can still have it on UCS E modules on ISR routers. You can find more details here
dwayne rattan
+5 for what Mohammed said. As he indicated you can use UCS-E 160 module and install CUC ova for 200 users or if you have vmware host that meet the requirements you can also use them.
Also an alternative to CUC would be to use Imagicle Auto Attendant.
