Changing Phone description for multiple devices
jonragnar
Hi all
My first post here.
I have custom descriptions for phones on the phone control field in Jabber
Like here
https://supportforums.cisco.com/discussion/11983771/multiple-selections-use-my-phone-calls-jabber-924
Where on CUCM do i change this?
I have turned every stone on our CUCM 10.5.2
Best regards
Jón Ragnar
Hi jonragnar,
 that's the correct behavior:
<'Device Type'>: for only one 'Device Type'
<'Device Type'>-<'Device Phone > Description'>: for 2 or more of the same 'Device Type'.
As soon as you have only one 9971 and only one 7940, the only option is the 'Device Type' ... if you have two 9971 (for example), then you would be able to change the Description.
Regards.
5 Replies 5
Hi ,
 Jabber uses the 'Device Phone > Description' field to differentiate 2 or more of the same 'Device Type'.
 If you only have one 'Device Type' then it only shows the 'Device Type'.
 In other words:
Hope this helps.
When i change the Device - Phone  - Description field i do not see that in my Jabber.
Hi jonragnar,
Regards.
Thank you
This works when i use 2 of the same devices
Has anyone come across another way to modify the description?
