cisco jabber not connected to AD
Iver Baldiviezo
Hello everyone
I have 1 problem with my cisco jabber for windows because they do not want to connect to the Active Directory of Windows Server 2012, also I can not search for contacts (Active Directory) in the search bar jabber. not that the problem should remain attentive to your valuable comments.
Note: CUCM Version 10.5
Thank you very much in advance, greetings.
Jaime Valencia
Are you simply using SRVs? or how did you configure the directory for your Jabber??
What troubleshooting have you done?
java
if this helps, please rate
